hey guys.
i want create this kind of Delay and “smear” effect.
(Beginner Problem) … how the Delay works? ;/ I used Frame Delay and Frame Delay Frame also in Combination with Frame Feedback but nothing happens. So seems i made smthg wrong.
The “smear” Overlay i would create via Particles and Fields.
ok. one easy solution. i put the Frame Delay behind Frame Feedback. (didn’t know that this is possible) It will delay every single frame.
I’m not sure you would need the frame delay node there, I think a frame feedback node set to max, with a reasonably high previous frame amount would do exactly what you are looking for here.
yep. right. it does
