Fail to load jpg seq at 16480x3096 pixels?
hi, jumping back into Notch ( using Demo) to evaluate if we can really abandon After Effects for offline content creation at 12k and 16k resolutions. AE is useless.
When trying to load a 2 minute jpg sequence at 16,480 x 3096, I get “Failed to Load” message.
Have I surpassed the max pixel size we can import? if so, does 1.0 handle larger pixel sizes?
Thanks
Chris
The max resolution is defined by DirectX here
It defines it as 16380 so you’re just a little over :slight_smile:
1.0 uses DX 11.3 so this resolution limit will be the same.
Hi James, OK that’s great to know. Thanks so much for clarifying this, very apricated!
