Export as 16 bit PNG
Hi!
Is there a way to export image sequences as 16 bit PNG?
Or will there be another format for exporting with that bit depth?
The “High Dynamic Range” parameter in the Root node doesn’t seem to change the export format…
Thanks for your help!
Hey,
We currently don’t support 16bit png.
You can, however, export in 16bit (half) .exr, and use openexr to verify the export.
Jack
