Notch block in 10-bit color
Hi,
I’m working on a project in the block/touch designer workflow, to be displayed on a LED screen set up and cabled for 10-bit.
My question is wether notch will actually generate 10-bit images with the high dynamic range ticked on the layer’s attribute menu.
Thanks a bunch,
JBH
Hi,
With High Dynamic Range enabled on the root node, an exported notch block will run at 16-bit channel. To make use of this in TouchDesigner you will need to change the Pixel Format of your Notch block inside TD to be 16-bit-float(RGBA). You do this in the Common section of the notch blocks parameters.
This will let you generate 16-bit images from your block in Touch. You can then convert that down to 10-bit for your display.
Hope this helps!
Well that’s great.
Passing the message to my fellow TD developer.
Take care
