Hi, guys.
i’m try to convert HDR content to NotchLC, but when i choose NotchLC format in media encoder, the output color is not right,
once i change to export tiff, then it have no problem
anyone know how to fix this?
thanks so much
lei
Hi, guys.
thanks so much
lei
NotchLC just provides a 0-1 float values for colours. How they are mapped (sRGB, Rec2020 etc) is up to you. NotchLC supports High Bit Depth content, but not HDR content - content with a wider colour gamut will be clipped outside the 0-1 range. You could try to squeeze the colour range into the 0-1 range and then separate it again in post, but you’ll lose a lot of colour depth trying to do so.
thanks so much for your explain
