We’re asked to deliver a project that’s in HLG & Rec2020, in NotchLC.
With Notch being a 10bit codec and HLG being a fairly “mild”, static HDR, there’s no limitation from rendering such HDR video in Notch — my question is more about metadata to process the files properly in Premiere, AE, and Notch Playback.
I can’t find any reference ever anywhere about NotchLC and HDR.
While After Effects allows overriding Notch clips’ color profile, Premiere does not.
Tests I ran today to transcode from an HLG HDR ProRes to Notch, in Premiere/Media Encoder, appear to suggest that it thinks it has to be a Rec709 destination and auto-converts it to SDR. It definitely doesn’t tag those Notch MOVs as HLG the way it does ProRes.
