is there any way to change multiple parameters at once like you can in Cinema 4d? In C4D you can hilight two parameters and hold ctrl to move both of their sliders at once.
As far as I know, you can only change one parameter in many nodes at once by selecting as many nodes as you want of the same type and dragging chosen value slider to your desired value.
Winged
Yeah it is nice that I can change the same parameter on multiple nodes at once but there are many situations when I need to change multiple parameters on the same node at once, such as changing the Y and Z scale of a cube.
