How do I get streaming input from my computer that’s running Notch?
For example I would like to listen to Spotify and use the input for audio-reactive effect.
Thank you.
Thank you.
Hi,
I found this solution a few days ago and it works.
https://www.nerds.de/en/loopbeaudio.html
I’m not aware of a free solution.
Mathias
In your sound settings, under Recording make sure stereo mix is set as your default device.
In notch, Devices>Audio and Midi Devices, select Stereo Mix in under audio capture devices.
Add a capture sound node, to scene, and use a sound modifier to check that its capturing!
Hope this helps!
Thank you Snailey! It worked!
Thank you! Snaily’s way worked for me but it’s good to know!
