Hello.
There is some way to copy and paste the keyframes?
Is posible to move one camera through a path?
Thanks.
Hello.
Thanks.
You can copy and paste keyframes in the curve editor by dragging to select the keyframes and doing ctrl-c and ctrl-v like you always do.
The camera can be moved along a spline with the Follow Spline node. Just make the Follow Spine node the parent of your camera and hook up a spline to the input and it should work.
Thanks Spencer!
