0.9.20 Release (Maintenance)
The new 0.9.20 release is now available. This is a maintenance release focusing on bug fixes and improvements, with the next major release due later (after Easter).
Download here: https://www.notch.one/support/downloads_area/
However, because we just love providing you new features there are a few…
  • Notch.exe is now a stub app that provides you licensing info / expiry dates on startup, then launches Builder.
  • Video rendering is now performed in a separate exe. this allows a) much better multicore support across all video rendering; and b) memory limitations to be lifted on video rendering. Faster rendering and larger canvases than ever are now possible.
  • Layer precomps: use an instance of a layer as a (video) node in another layer.
  • Post effects all have blend modes and channel switches.
  • DMX offset editor for exposed parameters. It’s the “Exposed” tab next to the other “Exposed” tab - and it’s not supported in any media servers… yet.
  • Kinect1 and Kinect2 skeleton support using the Kinect1 Skeleton and Kinect2 Skeleton Nodes. Enable Skeletons in Kinect1/Kinect2 video settings.
  • Support for the new Realsense cameras (D435 etc).
  • Support for Motive data streaming in - rigid bodies and markers.
  • FBX upgraded to 2018.
  • Artnet universes support for up to 32.
  • Materials/objects - multiple UV set support.
  • Scene nodes : material inputs on scene root node; shared across all objects in scene.
  • Procedurals can now be used to define falloffs on clone and particle affectors.
  • Picking : toggle on and off in toolbar, click to select 3d object under cursor.
  • ERTY keys to select manipulators.
  • SVG loading support
  • NDI - ability to rename NDI sender.
  • Faster and more memory-efficient TGA loading; TGA image sequence loading works
  • Copy nodes to/from clipboard as text, using “Copy To Clipboard” option under edit menu.
  • Timeline : ability to mark a time range; trim, cut and insert time from bars; stretch keyframes using ctrl while dragging time bars.
  • VRAM budgets : some user control over total VRAM usage in media servers.
  • Area lights from polygons and point lights from vertices - changed to support more types of input geometry.
  • Combine Geometry supports tangents.
Plus a whole load of bug fixes, small improvements and optimisations.
A new build has been released with a few minor fixes, including workarounds for the recent Intel driver upgrade of the new Realsense cameras and the problems it caused.
Hi, Matt.
Thanks for the info, but somehow the download link points to rc1. Is this a mistake?
Thank you,
Andy
By the way, Notch Trial download link has the same issue - 0.9.20rc1 available only.
Please, fix both links.
Thank you,
Andy
Hi Andrei,
It definitely links to rc2. Maybe your browser/proxy has cached something?
-Matt
Hi, Matt.
Indeed. I cleared my browser’s cache and all is fine now.
Many thanks for the tip.
Best,
Andy
