Hi!, Im experiencing an issue whenever I use a Render to Texture node, on the first frame, white squares appear where the textures are located, even with early evaluation checked. My current workaround is to have an opacity keyframe of 0 on the first frame, but since I need to replicate and change multiple nodes, this isnt very efficient.
I was wondering if someone has experienced this, and have a better solution. thanks
