hey,
Beginner Thing i guess.
How can i create this Video Retro Mirror Infinity Tunnel Effect?
I used Frame Feedback but this doesn’t create the Tunnel.
Indeed you can use Frame Feedback for that, just make sure you adjust the “Feedback Scale X & Y”, to something like 1.5, so the actual feedback doesn’t overlap with itself and gets scaled down so as to create that “tunnel-like” effect.
feedback_blur.dfx (6.7 KB)
super. thanks so much.
any chance to post a screenshot? i can’t open a File made with the Learning in my Base Version.
YESSSSS!!! thx a lot !!
