Hi,
Does anybody know what is the effect name of the subtle transparent moving lines/squares layer that breaks parts of the background in this demo (Stasse - Cocoon - https://youtu.be/D4-Fn1U0ZnY ) and if it is already available or easy to implement in notch?
Thank you,
R
Hello Raulabreu,
I think it is the randomise tiles post effect, the pattern is defined by the randomisation x,y inputs in the bottom of the node, in this case i just used a simple generator, I think Adrien might have used a specific video as an input there or some tweaked generator. Here is a screenshot and .dfx of the setup.
[attachment file=30163]
[attachment file=30165]
Wow… Thank you very much for the hint and taking the time to reply… Will explore changing the x,y inputs with different functions…
Thanks a lot!
hi!
i used the “bumpmap” fx with black and white image.
this fx is supposed to works with normal map…but…you can do cool stuff with juste simple map
the coolest thing is that you just have to animate the image used in the “bumpmap” fx ^^
here how it works :
I’ll share all the data from this demo later.
