Hello,
I’m trying to determine the cause of the problems in my standalone app.
Could it be the enabled OSC with a low bandwidth network?
Could it be the just updated ndivia driver?
Thanks for any hint,
Bruce
Hello,
Bruce
apparently, it works fine when I launch the app from the command line:
.\b.exe +logfile b1.txt +nosetup 1 +monitor 0 +windowed 1 +width 720 +height 1280
It removes the settings dialog, in which all the fields were blank…
What problems are you experiencing?
I guess it’s an issue with the former version I created, it’s now fixed
With the new version it works fine when I launch from the command line using +nosetup 1
If I double-click of the exe in explorer, the settings are blank, though…
