I’m trying to run a Standalone .exe on a fresh PC build. First attempt came up with a “missing msvcp120.dll” error. I looked it up and seemed like the best fix was to install the Visual C++ Redistributable. Now that I’ve installed that - when I double-click the Standalone .exe file, nothing happens.
Codemaster is installed, and my Playback license has been activated successfully on it. PC is running Windows 10 64-bit and has a 3090Ti card running the latest Nvidia Studio drivers.
Any help would be greatly appreciated!
SOLVED:
BitDefender was blocking the app silently without any reporting that it was doing so (even in the logs). Disabling BitDefender let the app run successfully.
More useful info on this here if anyone has similar issues: https://manual.notch.one/0.9.23/en/docs/faq/issues-starting-notch/
