Self Shadowing
Hello!
Fairly new to Notch, so excuse the rather basic question. I have an OBJ I’ve imported - and I’m looking to light it and then export the UV map to a media server. Media server side is sorted.
I’m struggling to enable the object to shadow itself using the Light node. Is there a tick box I have to hit? I have ticked the cast shadows one on the light etc.
Thanks!
I
Hey There,
Have you tried enabling deferred rendering in the root node? You may also need to enable Shadow Casting in the Light node.
Deferred rendering did it.
Thanks!
