Hi, guys.
I can’t find a way to make point particles (sprites) cast shadows onto other objects in the scene (e.g. 3d geometry). I enable the deferred rendering option in the Root Node, connect the Light node (with shadows enabled) to the Root and to the Point Renderer’s light input, turn on the Cast Shadows in the Point Renderer and… nothing happens. Any idea of how it’s supposed to work?
Thank you.
-Andy
Hi do You mean this?? if something else, please upload Your dfx file
Hi, Jan.
Yes. Thanks for the input. That’s exactly the effect I’m after. Tested your file in 3 different setups:
- Win7 64, Nvidia GeForce GTX780 Drivers ver. 381.89 -> NO PARTICLE SHADOWS
- Win7 64, Nvidia GeForce GTX1060 Drivers ver. 381.89 -> NO PARTICLE SHADOWS
- Win10 64, Nvidia GeForce GTX1060 Drivers ver. 385.41 -> NO PARTICLE SHADOWS
Looks like a hardware / driver specific issue. Would you mind posting your specs here for me to check them against mine?
Many thanks in advance.
-Andy
Jan,
One more thing: what’s your Notch version? Mine is 0.9.18.14.
Hi
Yes it’s a Notch realese reason… (I wrote before form not my account sorry :P)
