Is the select input node supposed to work with object?
As you can see here, the mesh emitter stays dashed when I connect it to select input node with an object connected to the input of that latter.
Is it normal or I’m doing something wrong?
Yeh that connection should work - the hashing out is a visual error we are looking to fix in the next release. If you have a scene where this isn’t actually working though, I’d love to take a look.
Hi Ryan
Great you’re right, it’s only a visual error.
