Hi hello
I’m having trouble with connecting a select input node to a video null.
In my setup I’m using multiple images into a select input node to create a video sequence inside Notch, and using that as a texture. However, I’d like to be able to add some fxs to my image sequence after the select input node, but connecting a video null doesn’t seem to work.
in this picture the blank node is the video null, shift-clicked to view its contents - as you can see it’s empty.
It works fine connecting the select input node to an image 2d or image plane, but since I can’t use any post fx on that I’m stuck adding post fx to every video loader node.
Is there a reason for this?
