Play Sound - Audio Glitching
Hi all,
Reporting this issue I’m having with the Play Sound Node.
My audio is working but it’s stuttering and glitching at random times, like skipping or backtracking frames.
I’m not loosing any FPS during playback.
Is there some magic box I need to tick to keep the track in sync?
Thanks
What kind of audio file are you using? Which codec and format? What sample rate? What audio system are you on (ASIO or MediaFoundation?)
What’s in your scene? Does your scene play the audio fine with all visuals disabled?
