Hi!
I’m a big fan of this post fx but i see that it include only 2 directions: left and down.
I’m wonder if there is a way to make that fx rotate so that you can apply in any directions: diagonally, right or up also.
Hi!
Hey there,  thanks for the feedback - we’ve heard this request before so its definitely in our consideration.
For now, you can use a transform node before the pixel sorting to rotate / flip the image, apply the effect, then transform the image again to flip things back to normal.  With the right values, you might be able to get arbitrary lines with that.
