Issue:
Using the Parent to Vertex node parented to a Null cause the child objects of the Parent to Vertex node to rotate at double speed of the parent object when rotating the Null.
Reproduction steps:
Connecting the Continous Modifier with a speed of 10 to the Rotate Lights Null.
Expected result:
Lights should rotate at the same rate as the other objects.
Actual result:
Lights rotate twice as fast.
Notes
Lights can be replaced with objects resulting in the same behaviour.
Connecting the Continous Modifier with a speed of 5 syncs up the motion.
Math Modifier/Sine exhibits the same issue, albeit somewhat exaggerated. Maybe suggesting a scaling/amplitude issue?
Scaling the parent object doesn’t seem to make a difference.
RotateBug.dfx (62.0 KB)
