Hi!
I’m trying to get OSC messages from TD into Notch. I’ve placed a OSC out inside TD with the local address set to my IPv4 (in Notch too) and I get tha name of the message inside Notch Monitor ( a /chan1 name and a value). The problem is that inside Notch this value doesn’t update. Just apears once and then it’s like frozen. If I change the name of the node inside TD, the new name and value appears in the OSC monitor inside Notch, but only once. Then the number doesn’t update.
Any ideas of what I’m doing wrong?
