NOTCH LC 100 definition
What does the 100 refer too?
I’m accustomed to optimal, best in settings but have a client requesting Notch LC 100…
Thanks
Andrew
I’m honestly not sure. Do you have a reference for where that term is being used?
Hi Graham,
It’s at the bottom of the graphic about performance
Written as notch LC @ 100
The quality slider (more specifically the range from ~75-100, or Optimal to Best) adjusts the resulting quality of the output based on some internal thresholds.
In this case, 100 is simply the maxed-out quality setting for these thresholds; Though the quality difference is not always noticeable.
What you will notice here though is a rather large jump in the file size, sometimes pushing a 20-25% increase.
If you have any further questions on this, please do let us know!
