Someone knows when i export my file want to use touchdesigner to play which is not in the middle of the screen even looks not full screen. …when i play my touchdesigner file or using moive player everything is fine…
Hey Hanrui,
You will need to provide a little bit more information here, what is wrong here? What type of export you are doing? Are you exporting something from Notch Builder or Touch designer?
