I’m building a live show and about to buy the Build license, and wondering about the best practice for use with Resolume, I won’t be utilising any other media server for the show.
If I midi map properties in Notch and then create an executable, are those MIDI inputs carried through so I can use my controller while running the .exe, or are they lost? If it’s the latter, I can try Bome to MIDI map the exposed parameters in the Web GUI but it will be an extra step, but if it’s the former, then I can put more time into MIDI mapping functions inside Notch now.
Hope this is clear enough
J
