Hello,
We are working on creating a touch-sensitive surface. To minimize blind spots caused by multiple users, we plan to install three Lidars positioned at different locations (left, top, and right).
When a single user interacts with the surface, each Lidar generates a detection point, resulting in three separate objects at the same location. Is there a method or approach to merge the data from the three Lidars so that, when they detect an obstacle in the same position, they trigger a single object instead of three?
Thank you for your assistance!
