Issues with OSC Exposed Parameters in Version 1
Hello Notchers,
Is the option to expose OSC parameters working correctly in Version 1? We’re experiencing issues connecting OSC from LightAct to a Notch block exported with the new RFX license.
When using Notch directly, everything works perfectly. When we use LightAct, we receive the signal in LightAct, and with Version 9 blocks, everything runs smoothly. However, with Version 1 blocks, we can’t get it to work.
Any ideas? Thanks in advance!
I’ve tested osc going in and out of Notch 1.0 blocks and its all working ok.
Only one block will be able to grab the port for osc, so make sure to close builder and any other blocks.
Which way are you sending OSC?
In case its useful for anyone else, the issue here was making sure that the “current value” property of an envelope modifier had been exposed, not the “value” property.
