Hi,
I wonder what is the best way to sync playback Notch with Resolume? I have Notch running on PC and Resolume on MAC. Computers are connected throw usb-c to thunderbolt.
Thanks!
You need to hook them up with OSC in a master/slave configuration. Deciding which one is the master depends on what you are planning to do with Resolume.
Thank you Spencer! I’ll try osc.
