How to make brush strokes?
Hello, I saw the video linked below and got to thinking about how one would create this effect. I’m honestly not sure how an effect like this could work in Notch. There seem to be two effects layered into one- the brush stroke and the water color spread. Any ideas?
Theres quite a few ways to do this, personally I would use Fields sourcing either particles or an image - both have pros/ccons, but you can make either effect with those work flows. The Field Fluid Affector will be the node to experiment with, that allows you to run a fluid sim on the field system, and with the right parameters you could get a really nice effect.
Thanks for the reply! I’ll give that a shot sometime and maybe post my results here.
