How to Enable NVIDIA face tracker in Notch
Hello,
If you are struggling with enabling Nvidia Facetracker in Notch, this video should help you out:
can I use face tracking with AMD GPU?
I’m currently running notch on bootcamp on MacBook Pro 16”
No, the NVIDIA GPU accelerated face tracker only works with NVIDIA GPUs. However, you can still use the CPU tracker which is GPU agnostic. However, that’s slower, has higher latency, and is less advanced.
