Hi everybody, I’m working on face projection mapping…
And so, using the face tracker node… I really like the result Fast and reactive… But I was wondering, if there is a way to smooth the noisy mouvement on the mesh?.. It’s a bit shaky …
Thanks
Thanks
This is an old thread, but I would love info on the same subject! Thanks!
The face will be erratic because the facial data wont be ideal. the NVIDIA tracker has come out since this post and its far more reliable than the CPU tracker, but If you still want to poke around with the CPU tracker then the only solution is to build your own database which is larger and/or more specific to your actor.
Here is a link to the manual page that shows you how to install the NVIDIA face tracker.
Please note, you need an RTX card to run this.
https://manual.notch.one/0.9.23/en/topic/nodes-video-processing-feature-tracking-face-tracker?
