Disguise Colour Correction HSL to RGB
Is it possible to change the way color is controlled in disguise from RGB to HSL when a colour correction node is exposed?
I am trying to make a global color correction node to use through the entre show and rgb is becoming extremely tricky to make subtle adjustments quickly. Would this need to be a complex math calculation in order to make that work or is there an easier work around?
Brian
