Is there a way to clone lights? Specifically I’m looking for a way to clone point lights with volumetric scattering - I have a character model with a laser in one of his eyes, and I want to clone this guy to create an army of laser eye men. Is this possible?
Hey Torbjorn,
If you need to use volumetrics with cloners, use the Light Scattering Beam node!
This should get you some of the way there. Bear in mind that the light scattering beam node isn’t actually a light - so you won’t get shadows or reflections.
In version 1.0 clones work with lights, so your laser men will definitely have their day soon!
