Hi, I am trying to import video with audio (quicktime / mp4)
But transcoded has no audio. I can separate video and audio with encoder, but i need to get video with audio.
I usually edit / export the source video in premiere.
Whilst in premiere :
I bounce out the video as normal
Bounce out the audio by itself.
Make sure the video is bouncing out at the correct FPS.
Upload both resources to notch via the encoder
drop video clip into the node graph (Video Loader Node)
drop audio into the node graph (Play Sound Node)
If everything is bounced properly it should sink up perfectly !
Hopefully this helps lol
