Geometry Exporter writes OBJ files, but the geometry is no visible in other 3d tools or even Notch itself. The OBJ file only contains Vertex data, but no Face data - which is usually needed for triangulation.
no-mesh.dfx (4.8 KB)
Hi,
It does look like a bug, i tried with different types of objects and open them in different tools. always the same result. i informed the development team about it.
Thanks for your feedback.
Regards,
Adrien
Thanks Adrien, I also tried several tools… I just wonder if this bug exists for a long time, since the exporter is still using “Demolition Builder” as a tag
