First proper day in Notch so total newbie question. Is it possible to move the anchor point on an imported 3d object?
Hi Andy, you cant directly unless you parent a null node to the 3d object.
Perfect. Thanks for the help Harris:)
Does this apply to all 3d objects? Curious if there is any way to adjust anchor points even on notch native geometry 3D items like text.
Hey Andy,
Parenting a null to your object is the only way to adjust geometry anchor points.
