Viewport layouts
Hello,
I’m really new to Notch and have just started learning. I come from 20+ years in Unity3D / 3dsmax and After effects and wondered if there is ways of having a few viewports - top / left / main and so on?
I’m working on a 7:1 ratio project for a client and usually you would see the camera viewport (0) at 7:1 and then have another setup that just fills the screen so you can stage the assets (5).
I’m also in a situation where I only have 1 monitor.
Anyways,
Hoping there might be a solution.
Notch doesn’t support multiple camera views at present, you’ll have to make do with the one viewport.
