Hi
This link seems to be broken.
http://manual.notch.one/1/en/topic/kinect-setup
Is there no documentation on using the Kinect v2 in Notch?
Hi
That link does indeed not work - where did you find it? When in doubt, just go straight to manual.notch.one and search there instead: http://manual.notch.one/0.9.23/en/topic/kinect-setup
Thanks. Result of google search
What did you search for / do you have a link? It would be good to try to clean up those old search results.
