Simple Constant or Value Node?
Hi all,
Silly question i’m sure, but couldn’t find the answer in docs or forums.
I want a node where I can simply enter a value, maybe animate it, and use that output to control lots of other values.
Does a node like this exist?
I’m currently scaling down a Sin to 0 in a Math modifier and Offsetting it to do this, so thought i’d check if there is a better way.
Thanks!
Envelope Modifier is your friend here.
legend, thanks!
MattB
