Hey
right now trying to use a select child node with deformers and seems it’s not working?
Thanks
Hey
Thanks
logic nodes (select child, execute child, etc) don’t work together with deformers at present, I would just use modifiers to switch their blend amounts.
thanks, Ryan
yes true this is what I’m doing but like slice node doesn’t have blend
so right now using the timeline to turn on and off, would love it to be more procedural
Depending on the heaviness of your scene, you could get away with “hacking it” so you just use a modifier to drive the thickness value (set it to 0 to have zero slicing). Might not work for your specific scene, but worth a shot
