Hi there.
The only post about this topic I could find here is 2 years old so I figured I should ask again.
Does anyone knows about outputing key and fill to discrete SDI outputs on blackmagic/aja cards like those Decklink Duo2 Mini?
I think it is completely possible to route only the alpha channel from a video clip or some 3d render independently to a separate output and use them with broadcast systems to overlay my project on top of an IMAG signal.
Does anyone have experience with this method?
Thanks a lot any input is appreciated!
