Hi, I’m having trouble figuring how to bring an SDI input into Notch, is this possible? Thanks so much for your help!
SDI is a physical connector, so if you have an SDI signal, you’ll need to capture that using a capture card. Notch supports capture devices that uses DirectShow or Media Foundation.
Thanks, I figured out that I needed to uncheck the Media Foundation box in the Video In settings. I’m using an AJA Kona 5, which is Direct Show apparently
Great to hear you got it working
im use KONA5 too…But KONA5 is still not recognized in the notch settings? I use the win11 pro version of the operating system, does this have something to do with it?
