Hi!
Is there a way to control via MIDI or OSC the active layer inside the Builder? I can’t find any info about this.
Thanks!
Hi!
Thanks!
No, this would be pretty confusing if you had outside sources changing layers while you are using builder. Changing layers with midi / osc is only possible with exported blocks or standalone projects.
Ok, let’s try a different aproach … Is there a way to select with an external modifier the “Source Layer” inside a “Precomp Layer” node? Modifiers doesn’t seem to connect to this tab …
Ok, so after seen one tutorial I discovered the Bins section and inside there was the Layer change object.
