Hi guys,
just got my Notch PLE dongle license and have couple of issues with it.
Every time when I try to start application I get this message inside CodeMeter Events Log
I can just see Notch splash screen and nothing happens. Tried several types/versions of Nvidia drivers (Alienware 15 R2, GEforce GTX 980M, WIN10 64bit), but no luck. Could anybody point me into right direction? Really appreciate it! Thanks.
Getting the same problem on a Builder key:
2019-02-15 11:03:04: Logging activated.
2019-02-15 11:03:04: CodeMeter for Windows (B6.50.2631.502.32.180)
2019-02-15 11:03:04: Running on Microsoft Windows 10 Home 1803, 64-Bit
2019-02-15 11:03:04: Execution path: C:\Program Files (x86)\CodeMeter\Runtime\bin
2019-02-15 11:03:04: Found IPv4 address: 127.0.0.1 | 172.16.1.55
2019-02-15 11:03:04: Found IPv6 address: ::1 | fe80::9149:2594:fe1d:365f%7 | fe80::c493:ff4f:be97:9148%10 | fe80::d867:d9bf:1381:47ec%17 | fe80::d958:af68:8c53:a0fa%8 | fe80::eb:de2:c3ba:24a9%6
2019-02-15 11:03:04: Used Communication Mode (Client): IPv6 IPv4 SharedMemory
2019-02-15 11:03:04: Used Communication Mode (Server): IPv6 IPv4 SharedMemory
2019-02-15 11:03:04: Used IP address: default address
2019-02-15 11:03:04: Used IP port: 22350
2019-02-15 11:03:04: Used CmWAN port: 22351
2019-02-15 11:03:04: Multicast server search: not available
2019-02-15 11:03:04: Run as network server: no
2019-02-15 11:03:04: Run as CmWAN server: no
2019-02-15 11:03:04: Run as system service: yes
2019-02-15 11:03:04: Service startup delay: 5:50 minutes
2019-02-15 11:03:04: Box Access: use direct access mode
2019-02-15 11:03:05: The list of available CmContainers has been updated!
2019-02-15 11:03:05: Detecting CmContainer with Serial Number 3-3824959 (HID)
2019-02-15 11:03:05: A new CmContainer is available (currently found 1)!
2019-02-15 11:03:05: Found new entries: 1
2019-02-15 11:03:05: Access from local(IPV6) to SubSystem (Handle 16)
2019-02-15 11:03:05: Handle 16 released
2019-02-15 11:03:06: Access from local(IPV6) to SubSystem (Handle 23)
2019-02-15 11:03:06: Handle 23 released
2019-02-15 11:03:18: Access from local(IPV6)(MSI\satoriteller,FXBase.dll) to FC:PC=102820:800 with StationShare Mode (Handle 32)
2019-02-15 11:03:19: Access from local(IPV6)(MSI\satoriteller,NotchApp.exe) to FC:PC=102820:800 with StationShare Mode (Handle 34) (Sharing with handle 32)
2019-02-15 11:03:19: Entry (102820:899) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:19: API Error 200 (ENTRY NOT FOUND) occurred!
2019-02-15 11:03:19: FC:PC=102820:880 : Expiration Time is expired.
2019-02-15 11:03:19: Entry (102820:880) not found - Event WB0035 (EXPIRATION TIME OVERRUN), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:19: API Error 35 (EXPIRATION TIME OVERRUN) occurred!
2019-02-15 11:03:19: Entry (102820:850) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:19: Entry (102820:810) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:19: Executing Broadcast for CodeMeter License Servers
2019-02-15 11:03:20: Entry (102820:805) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:20: API Error 200 (ENTRY NOT FOUND) occurred!
2019-02-15 11:03:20: Entry (102820:899) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:20: FC:PC=102820:880 : Expiration Time is expired.
2019-02-15 11:03:20: Entry (102820:880) not found - Event WB0035 (EXPIRATION TIME OVERRUN), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:20: API Error 35 (EXPIRATION TIME OVERRUN) occurred!
2019-02-15 11:03:20: Entry (102820:850) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:20: Executing Broadcast for CodeMeter License Servers
2019-02-15 11:03:21: Entry (102820:805) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:21: API Error 200 (ENTRY NOT FOUND) occurred!
2019-02-15 11:03:21: Entry (102820:810) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV6)(MSI\satoriteller,NotchApp.exe) with NoUserLimit
2019-02-15 11:03:24: Handle 34 released
2019-02-15 11:03:25: Handle 32 released
Was this ever solved? I believe I am having similar issues. I tried using by Disguise dongle with the PLE activation from Notch. Disguise still works fine, but Notch gives me the splash screen and closes immediately.
2020-04-17 16:00:59: Removable Device has been plugged IN/OUT!
2020-04-17 16:00:59: The list of available CmContainers has been updated!
2020-04-17 16:00:59: Detecting CmContainer with Serial Number 3-3824299 (HID)
2020-04-17 16:00:59: A new CmContainer is available (currently found 1)!
2020-04-17 16:00:59: Found new entries: 2
2020-04-17 16:01:00: Access from local(IPV4) to SubSystem (Handle 127)
2020-04-17 16:01:00: Handle 127 released
2020-04-17 16:01:05: Access from local(IPV4)(METOPERA\AAurora) to SubSystem (Handle 133)
2020-04-17 16:01:05: Entry (3-3824299 102820:2000) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(METOPERA\AAurora) with NoUserLimit
2020-04-17 16:01:05: API Error 200 (ENTRY NOT FOUND) occurred!
2020-04-17 16:01:05: Entry (128-13519318 102820:2000) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(METOPERA\AAurora) with NoUserLimit
2020-04-17 16:01:05: Entry (130-808859764 102820:2000) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(METOPERA\AAurora) with NoUserLimit
2020-04-17 16:01:05: Handle 133 released
2020-04-17 16:01:05: Access from local(IPV4)(METOPERA\AAurora) to SubSystem (Handle 136)
2020-04-17 16:01:05: Access from local(IPV4)(METOPERA\AAurora) to FC=102820 (Handle 137)
2020-04-17 16:01:05: Access from local(IPV4)(METOPERA\AAurora) to FC:PC=102820:805 with NoUserLimit (Handle 1041)
2020-04-17 16:01:05: Handle 1041 released
2020-04-17 16:01:05: Handle 137 released
2020-04-17 16:01:05: Executing Broadcast for CodeMeter License Servers
2020-04-17 16:01:07: Entry (128-13519318 102820:0) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(METOPERA\AAurora) with NoUserLimit
2020-04-17 16:01:07: API Error 200 (ENTRY NOT FOUND) occurred!
2020-04-17 16:01:07: Entry (130-808859764 102820:0) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(METOPERA\AAurora) with NoUserLimit
2020-04-17 16:01:07: Handle 136 released
2020-04-17 16:01:07: Entry (0:0) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(METOPERA\AAurora) with UserLimit
2020-04-17 16:01:08: Access from local(IPV4)(METOPERA\AAurora,FXBase.dll) (SID 0x00) to FC:PC=102820:800 with StationShare Mode (Handle 142)
2020-04-17 16:01:08: Access from local(IPV4)(METOPERA\AAurora,NotchApp.exe) (SID 0x00) to FC:PC=102820:800 with StationShare Mode (Handle 144) (Sharing with handle 142)
2020-04-17 16:01:12: Handle 142 automatically released.The application is no longer available.
2020-04-17 16:01:12: Handle 144 automatically released.The application is no longer available.
