Kinect over longer distances
Just looking into the best cables for using the kinect azur at 10 meters (and eventually up to 30 meters)
Is this possible with the right high-spec usb-c cables or is it just not recommended? Any brands you would recommend?
Thanks in advance.
Bought this one a few days ago. Haven’t tested it much - ran it only a few minutes in the store , but so far it works.
https://www.logitech.com/en-gb/product/strong-usb?fbclid=IwAR1gl2yZhDre94FAESdMqwStGxSB7RyN5t4RQ2ZI573eAVFSmLVqMICP6h4
Cheers! I was looking at the ones marketed for oculus as that seemed a comparable load, will check this one out too
The Occulus ones are a lot cheaper. I don’t know if they can work since I have not tested them. Also going by memory I think I have only seen 5m long, not sure if they are active. Please let us know if you test one of the Occulus cables succefsully:)
