Dear all, I hope this meets you well.
Is there a way to record the render screen while changing parameters live with touch Osc or midi controllers ?
Thank you
Thank you
easiest way is to use NVIDIA shadow play or AMDs equivalent, allows you to record content with a very minimal impact on performance.
