Hello,
Curious how to export a quicktime file that combines all of the Play Sound nodes in a nodegraph. Currently, it seems that only one Play Sound node is exported.
Hello,
Just had a look into this for you and it looks like there’s a bug with it. From what I’ve just tested, only the most recent Play Sound node gets rendered out.
We’ll log this into our bug tracker and have a look at a fix for this. Thanks for bringing it to our attention!
–James
Understood. Looking forward to the patch. Appreciated, James.
