Gradient Remap - Option to enter values instead of drag points
Hey Captains,
Is there a way to enter values or adjust curves in the Gradient remap besides dragging up and down on the curve in the properties panel?
Even to be able to adjust the curve points in the curve editor, just trying to place exact values at certain ranges.
Directly editing values in this node isn’t possible right now - but we’re looking at options for this closely for the next release. in the mean time, one good option for this kind of workflow is to look at the keyframe remap bin. Keyframes on the nulls y position can be used to animate through a value with a lot more control than the gradient remap.
