Full Dome in Notch?
Hi there,
Is possible to output Full Dome or Full Dome Stereoscopic from Notch, a movie file and or realtime?
Many thanks,
Rosendo
I think fisheye camera can work for this task
Thank you Misha I will try it!:+1:
Hi Guys,
Any updates on rendering for a dome? Does any one know the right camera setup step by step in Notch?
Thanks
Hey there
Curious about this too. I have tried bringing in a hemisphere into Notch from C4D via.c4d file, but it seems the interior is not picking up i.e. lighting + material. It might be from UV mapping. Screenshot attached.
Thoughts?
Thanks ~
Tick “Flip Polygons” in your Imported 3D Scene node.
Or use a Material with the “Backface Cull Mode” attribute set to “Double Sided”.
